Old 10-03-2019, 05:51 PM   #1
Default antenna
Does anyone know where the tv antenna on an 2002 Roadtrek 200 Popular is located? It seems to be in a wall or somewhere not easily accessed. It is definitely not on the roof or in any cabinets. Suggestions as most of the time it does not pickup any stations.
Thanks
Grampy
Grampy is offline   Reply With Quote
Old 10-03-2019, 07:54 PM   #2
Thanks
Grampy
It is up against the roof on the inside, left side. It does seem to be directional so turning the van sometimes helps. No one has said it was very good.
I use a Winegard Automatic which is a domed, motor driven, over the air antenna. The third one seems to be hanging in there. The first two failed the gear case. About $300. Really happy with it as long as it doesn’t die again.
Old 10-04-2019, 01:55 AM   #3
Thank you will probably have to upgrade to something better.
