Old 08-25-2018, 03:31 AM   #1
Default Another “What Should I Get” Question
First off, this is my first post and I just want to thank everyone for their posts to this forum. It’s the quality of the posts that make the forum, and there is a lot of quality here. Second, let me introduce myself and give you context for my question. I am a total RV newbie living in Alaska. I would like to do some extensive domestic travel but I hate all the small indignities: standing in lines at airports and elsewhere; sleeping in unfamiliar beds; packing and unpacking; having schedules to make and keep; etc. A class B will allow me to travel Alaska and the lower 48 without most of these indignities, even if I will have to put up with some new ones: dumping tanks; putting up with things breaking; etc.
I believe that I will be putting in an order for delivery maybe next spring or the following spring. I’ll be buying new because I can afford it, I am intrigued by the new technology like the Volta or Xantrex systems (one less internal combustion engine to worry about), and it is very unlikely that there will be a used unit in Alaska that I’d want to buy. I value quality and reliability and would be willing to pay *something* for them, so I’d consider some of the more expensive OEMs.
Given all this I believe that I have two options:
1) Buy a Travato GL in Alaska. It makes a lot of sense for me to buy a RV close to where I live so that I can take it back into the dealer, possibly many times, during the warranty period without being far from a home base. The only new class B that I know I can get through a local dealer is a Travato. It seems likely to me that the lead time on a Travato may be short enough that I can order one this fall and still get a GL by next May/June (i.e. spring in Anchorage). I am watching closely to see how reliable the Volta system is on the Travato. The downside of a Travato is that the lack of quality and reliability, the short warranty, and a more custom rig could have better insulation and design for colder climates. But I think I could live with these tradeoffs for the floorplan and the Volta system.
2) Buy something pricier like a Sportsmobile, Advanced RV, Midwest Automotive Design, or Outside Van in the lower 48. If I have to travel to the lower 48 to pick up a rig, I want to limit myself to OEMs that offer quality, pre-tested units that will work for at least a good amount of time after I drive one off the lot. One problem here is lead-time – I believe that most (all?) of these OEM have long backlogs so i will need to limit myself to spring 2020 (or possibly even later?). Another problem may be value obtained per unit dollar (based on ARV’s used listings, they must be getting $300k and up for their new rigs (wow) whereas RV Trader data suggests that the other quality/custom OEMs may be more reasonable.
So:
1) Should I choose an Alaska-delivered Travato or something nicer in the lower 48?
2) Am I fooling myself to think that these are my two best options?
3) Should I be so concerned about picking a new unit up so far from home?
4) Will the more expensive OEMs be materially more reliable and offer materially better customer service?
5) How much do rigs from each of the fancier OEMs really cost if one doesn’t care about fancy fabrics, etc. but does want things like better cold weather range and the flexibility of having no generator (so I can be stealthy but still have the flexibility to park overnight someplace hot)? I don’t want to limit myself to campgrounds, especially crowded campgrounds.
Thanks in advanced for any help. All comments greatly appreciated.
Snowy is offline   Reply With Quote
Old 08-25-2018, 04:16 AM   #2
Note: Check the temperature limitation of lithium batteries.
Old 08-25-2018, 05:06 AM   #3
Knit's Avatar
Great choices. My opinion would be buy something with a nearby competent dealer so you can use it for a while and get all the inevitable problems fixed. Then hit the road.
Knit is offline   Reply With Quote
Old 08-25-2018, 05:40 AM   #4
This is definitely a good comment and a valid concern. Based on Advanced RV white paper:
https://advanced-rv.com/wp-content/u...hite-Paper.pdf,
Volta batteries can charge and discharge down to freezing and -4F, respectively. Volta batteries can be stored all winter at -4F, and down to -40F "for short periods." Xantrex batteries can also charge and discharge down to freezing and -4F, respectively, but they can't be stored below -4F.
My current thinking is none of this matters while i am using the rig since a properly insulated and heated battery box can easily be kept above freezing, especially with me there all the time and running the engine, etc. If the Travato does not come with a proper battery box, i can add insulation and some heat tape (or perhaps some better heater) for not much money.
Storage could be a problem but it rarely gets below -4F here in the hills around Anchorage. I can't believe that it would ever get too cold to store the Volta batteries here. As for the Xantrex batteries, if it does threaten to get cold enough for a concern, i can always plug the rig into shore power to keep the battery heaters going. I can even, i believe, install some sensor system to send my phone temperate status and alert messages for not much money.
Thanks for asking this question. Responding has helped me clarify my current thinking about this. Is my current thinking faulty in some way?
Old 08-25-2018, 07:01 AM   #5
Considering where your home base is and that WGO service is pretty much the only game in town, I think your focusing on the 59kl or 59gl is a good choice.
But where you buy the coach is another matter. The conventional wisdom is that you are more likely to get better service from the dealer you buy the coach from but that hasn't been my personal experience. You will probably be hit with serious freight charges for taking delivery in Alaska rather than taking delivery at a dealer that's close to the factory.
Purchase price in Alaska is another thing you will need to consider. WGO discounts from MSRP are typically 25% and I have received a quote for a 59kl from an east coast dealer that offered a 30% discount. My guess is that your local dealer has the advantage of a less competitive environment and will be less generous with their discount. Go to them with the best price you can get from other dealers and see if they will meet it. If they will, the freight surcharge might be worth it.
I wouldn't be the least concerned about where you buy the coach. The warranty travels with you.
IMO to get a significant increase in reliability and warranty service you will have to look at the top of the line like Advanced RV or a custom built Sportsmobile but you will spend a lot more money to accomplish it and I don't think it's worth it. The Travato 59kl or gl is the best bang for the buck in the B class. I wouldn't worry about the Volta system. Volta has been providing similar systems to high end class A coaches for a sufficiently long period to iron out any bugs.
Old 08-28-2018, 09:01 AM   #6
Just now I've seen the PDF you shared with us, very detailed information about the RV battery. Most batteries should be used at -20℃ to -60℃, while LiFePO4 can work at -20℃ to -75℃. At extreme temperature of 350-500℃, it still works.
Monica998 is offline   Reply With Quote
Old 08-28-2018, 11:34 AM   #7
ponti33602's Avatar
We bought our Van in NJ and live in Florida. We have been to our local guy twice for warranty issues and the service folks "could have cared less" where we purchased from. I have read stories from others not so fortunate but for us the trip saved 3% even after the quick flight and drive.
Regards,
Bob
2017 RT Agile SS
ponti33602 is offline   Reply With Quote
Old 09-24-2018, 05:07 AM   #8
In Oregon, dealers will not service your RV if you bought it somewhere else. That's been said to me by every dealer I have visited.
krbmmrn is offline   Reply With Quote
Old 09-25-2018, 07:12 PM   #9
This may be too late to be helpful, but I do think renting is a good way to figure out what you might want in an RV and if you enjoy it. Rvshare may have something relatively local to check out, or if you are serious about something like ARV you could schedule a trip to southern California or Ohio. Most people look at the rental price and think they would rather put the money into a purchase, but transaction costs are high if you buy something and don't like it.
Many of ARV's used units are pretty optioned out which may put their price at the upper end of what is possible in a build, but if you are like me you might find you want a lot of those options once you look into them. A used unit may allow you to get something right away, but it helps to be handy with anything used. As for lithium battery storage, if you can store your RV plugged in, it isn't really a problem, there are people in Minnesota who have had lithium batteries without issues.
Mfturner is offline   Reply With Quote
Old 09-25-2018, 07:52 PM   #10
I think this is somewhat dependent on the particular upbuilder. Some have no contractual arrangement for service of their coaches. I think Roadtrek dealers are obligated to service and repair Roadtreks regardless of the origin of purchase. Further, I believe they can bill at their regular shop rate rather than some diminished flat rate. But that said, as a practical matter, there is no way to prevent a dealer from stalling your repair into oblivion.
FWIW, the internet has generally resulted in nationwide competition for your purchase but from what I've run across, RV dealers in Oregon are in a non-competitive world of their own.
Old 09-26-2018, 02:12 PM   #11
I am sure that my dealer will use every reason he can think of to try to justify why i should pay more than that offered by lower 48 dealers. They are the only dealer of class Bs for thousands of miles and they know it, so they won't match lower 48 pricing. The question for me is how much of a premium i should pay to get the rig delivered up here and possibly get more timely service
Old 09-26-2018, 02:29 PM   #12
ponti33602's Avatar
Only my opinion so take with a grain of salt as everyone's situation is unique to them.....................
We saved ~$5K over local. Which more than double covered flying to get it and drive it 1,000 miles. I actually wanted to do this as this is the first vehicle of this type and thought it was a good way to become familiar with it.
Anyway, I knew I would not have an issue with local service. That being said if you know you will, for me $5K premium would probably be "my" magic number.
Regards,
Bob
2017 RT Agile SS
Old 09-26-2018, 02:46 PM   #13
I don't know that i will get worse or less timely service if i buy elsewhere, but there is that chance. Based upon what i have read in this and other forums, i do expect that the dealer will claim that i won't get service or timely service or something like that if i do not buy from him.
It is interesting that you state that your magic number might just have been $5k, and that this was also the premium your local dealer had chosen to settle on. Perhaps dealers have a good idea what most people will pay to avoid buying from afar, and stick to that number when faced with buyers showing up with quotes from distant dealers.
Old 09-26-2018, 02:48 PM   #14
ponti33602's Avatar
Perhaps.........my dealer could have cared less......same as auto where they treat service as a separate business unit all by itself so they don't "bite off their nose"........and I have been back for warranty issues twice.
Regards,
Bob
2017 RT Agile SS
Old 09-26-2018, 10:38 PM   #15
There are also mobile RV mechanics around here unaffiliated with dealers, I don't know about in Anchorage though. There is enough competition here that I'm not worried about intentional stalling, but I do know they get backed up...
Old 09-26-2018, 10:58 PM   #16
How do i search for such mechanics? I did a search through this forum and could not find anything and all google lead me to is the RVIA certification program which strangely did not have a way to search for their members, at least none that i could find.
Old 09-26-2018, 11:05 PM   #17
Just a plain Google search of "RV mechanics near me" gave me a half dozen options here North of Denver, but as I said, we have a lot of RV dealers here so there must be a thriving market... It won't be the same everywhere and you'll have to find a way to vet them like you would an independent car mechanic.
Old 09-27-2018, 02:36 PM   #18
Phoebe3's Avatar
We found it was a lot less trouble and not very expensive to find a local RV shop that was not affiliated with a dealer. Most warranty issues will be with a subcomponent and those parts (and sometime labor) are covered by the maker (e.g., Dometic, Nova Kool, etc.).
Of course, you may need warranty work on electrical or plumbing or cabinetry and that is going to require a dealer, but it may also not cost very much to just pay a private RV repair shop out of pocket, particularly if you saved a couple thousand dollars by buying elsewhere.
2018 Coachmen Crossfit/Beyond
