Old 09-19-2017, 12:53 AM   #1
Default Aktiv Window dimensions
Hello all!
Looking for the exact window dimensions in the Hymer Aktiv. I'm converting a 159" WB Promaster and am ordering Seitz s7p windows from Germany (same as those in the Aktiv).
I'm looking for the following dimensions:
Main large windows (2): sliding door/across from sliding door (exterior glass/frame, interior dimensions of shade/bug screen assembly)
Aft side panel windows (2): Long/narrow windows, (exterior glass/frame, interior dimensions of shade/bug screen assembly)
Rear door windows (2): (exterior glass/frame, interior dimensions of shade/bug screen assembly)
If anyone has an Aktiv and wouldn't mind taking the measurements, I'd be SO appreciative. OR, if anyone has tips as to where this information may already exist, that would be great as well. Thanks!
kifo4173 is offline   Reply With Quote
Old 09-19-2017, 02:08 AM   #2
Probably Seitz has the info.
The ProMaster/Ducato is a very popular RV platform in Europe. I am sure they are well versed in what you need.
Old 09-19-2017, 02:20 AM   #3
If there is no one here, check out the Facebook group... quite a few owners there.
https://www.facebook.com/groups/aktivowners/
2015 Roadtrek 170
2011 LTV Libero
2004 GWV Classic Supreme
Old 09-19-2017, 03:29 AM   #4
wincrasher's Avatar
There are also a couple Aktiv owners in my group - you might hit them up.
2019 Winnebago Travato GL
Old 09-19-2017, 04:15 AM   #5
Thanks for the help all.
I've found out some good information. The stickers/imprints on the windows in the corners give the exact measurements in mm. If anyone with an Aktiv minds checking and either posting the images of the stickers/imprints OR using my attached image to figure out the sizes, it would be awesome!
Thanks for the suggestions of where to find Aktiv owners, I'll try some of those. Cross posting here in case an Aktiv owner sees this first!
