Old 07-01-2010, 08:57 PM   #1
Default Airstream Interstate 2007
Hi....Brand new member here....Does anyone have thoughts about how to make the rear sleeper bed in my 2007 Interstate RV into an electric bed instead of jack knife? I have not slept a wink in it so far.....PLEASE help our sleepless......
gail is offline   Reply With Quote
Old 07-01-2010, 09:45 PM   #2
Default Re: Airstream Interstate 2007
Is it not comfortable or just difficult to set up?
It probably can be done and I guess it depends on how much you want to spend.
Is it like this?
This is the model with the electric sofa:
If it is not comfortable then, if you have space, consider carrying a foam topper or memory foam.
Old 07-06-2010, 01:34 AM   #3
Mike's Avatar
I'm not sure I understand how the electric bed will be any more comfortable than the jack knife,
unless it has fewer cushions or pieces than the jack knife, and therefore fewer gaps between
them. I'm looking at the photo marko put up, and it looks like a tetris puzzle, so if it were me,
I'd try marko's suggestion and look for a solid topper/pad of some sort, if that's the issue.
When our bed is made up as a king, the cushions run north/south mostly so the cracks are
parallel to how we usually sleep. It took us some getting used to, but if/when you do, you
might be surprised how good you'll sleep.
Good luck.
