Old 04-01-2021, 12:27 AM   #1
Default Air Conditioner Won’t Run on Generator?
We own a 2018 Winnebago ERA 170X. When connected to shore power at a campsite, the A/C works great. But when we’re dry camping or without electricity for some reason, I cannot get the A/C to come on with the generator running. I fire the generator, wait five minutes, then attempt to start my A/C and complete silence. I have other appliances off prior to attempt starting the A/C. One time it came on after the generator had been running 20 minutes or so. I note the Precision Circuits control board shows “AC on”. I also see “Compr Wait” and a two minute countdown. Even if waiting those two minutes and then trying to start, no luck. And I even broke down and read the owners manual. Any suggestions?
theHueg is offline   Reply With Quote
Old 04-01-2021, 02:04 AM   #2
i was going to say maybe the generators not actually connected-but you say it worked once- so maybe you need a 'hard start capacitor' for the air conditioner.
Old 04-01-2021, 03:24 AM   #3
Perhaps transfer switch generator <> shore is not working. Do you have power on AC outlets with generator on?
Old 04-02-2021, 01:54 AM   #4
No power at outlets with generator running.
Old 04-02-2021, 02:26 AM   #5
Seems as your transfer switch is kaput, perhaps wiring. See this video. A way to diagnose is to listen for clicking, as transfer is switching from shore to generator and back it will click.
Edit - I would check if you getting voltage at the generator, if not than generator is kaput.
Old 04-06-2021, 03:18 AM   #6
The breaker on the generator itself (had to crawl under the RV) was tripped.
Old 04-06-2021, 11:03 AM   #7
I recently overloaded my generator by stupidly turning on the Truma heat and hot water, both on high and lost AC. I was thinking there might be a breaker on the generator but haven’t looked yet. I took a quick look and saw what looked like a key lock on the generator, hopefully the breaker is not locked up as I don’t have a key. Can I get to the breaker without a key?
magicbus is offline   Reply With Quote
Old 04-06-2021, 02:07 PM   #8
What appears to be a key hole may actually be what mine was, a large slotted fastener. Rotate with a slotted screwdriver, open door, and put a finger inside downward and flip the switch.
Old 04-06-2021, 04:15 PM   #9
Thanks so much. Mine is also a 2018 so I expect we have the same generator and I will crawl under and check it out. Thinking I needed a key has been making me put it off!
Dave
Era 170A
Old 04-10-2021, 04:25 PM   #10
Thanks again. You took a potentially big job and turned into a two minute fix. And the tip about reaching down for the breaker was really helpful as it can’t be seen.
And since it was so easy I wire brushed and sprayed Rustoleum on the battery and generator brackets.
Dave
Era 170A
Old 08-02-2022, 06:28 PM   #11
Thanks to this post I was saved a lot of money and embarrassment if I had gone to the dealer. I found the generator circuit breaker on the generator, Onan 2500, hidden below the start button. You can't see it without removing the access panel, shining a flashlight down the panel area, getting you head up next to the start button and looking down with one eye below the start button. There is a yellow 2" long switch. In was in the down position and needed to be in the up position. A flick of the switch, a start of the generator and now my AC works when the generator is running!
jerryt is offline   Reply With Quote
