Old 03-08-2016, 09:30 PM   #1
Default AC Power Not Running
I have a 1998 Jayco Campervan. I can not get any device plugged into the AC power to work. Does anyone have any suggestions. Thank you for your help.
shamrock is offline   Reply With Quote
Old 03-08-2016, 10:39 PM   #2
eric1514's Avatar
You do understand that AC inside the van will only work if you are plugged into a source that provides AC like a generator or your house or a campsite that provides the juice. If you know that, then start at the panel where all your breakers are and see that they are turned on.
Good luck,
Eric
"Il Travato Rosso"
2015 Travato 59g
Old 03-09-2016, 12:20 AM   #3
Also check the GFCI outlet to make sure it didn't trip in addition to checking the circuit breakers.
JamesM is offline   Reply With Quote
