Old 08-04-2022, 01:10 AM   #1
Default 97 Roadtrek 190 water system question
Hi all.
I have a 97 Roadtrek 190 Popular Dodge chassis, and any time I hookup the city water connection under the water heater, my fresh water tank starts over flowing.
I don't have a paper manual for it, and I've searched the pdf one I downloaded for any sort of shutoff valve and didn't see anything. *Edit- I have made sure all faucet knobs are off to avoid crossover in that area as well*
Any help is appreciated, pictures are regarded as gold! ��
BigHoss is offline   Reply With Quote
Old 08-04-2022, 01:29 AM   #2
Originally Posted by BigHoss View Post
Hi all.
Owners manual here:
http://file:///C:/Users/lever/Downlo...All_Models.pdf
Normally there is a tank fill valve to fill the fresh tank from the shore water inlet connection. Probably located by the shore water connection. See page 9.
Old 08-04-2022, 03:23 PM   #3
mloganusda's Avatar
From other's experience, you have a bad backflow preventor that is attached to your freshwater line at your water pump or internal inside the water pump.. Check pluming diagram.
Old 08-04-2022, 03:53 PM   #4
Owners manual here:
The link you gave didn't load, but I checked page 9 and did see about that valve. It was turned on, and shutting it solved the problem. Simple fix 🤪 Thanks!!
