Old 08-11-2016, 10:03 PM   #1
Default 96 Roadtrek outside shower faucet set
Are there washers that can be changed in the faucet set, appears to be cheap plastic valve set. It is the original , so its 20 plus years old. If you need to change the entire set , how do you access it. appears to be under hot water unit, accessable from inside???
95Pop210 is offline   Reply With Quote
