Old 02-20-2015, 10:44 PM   #1
Default 2010 Pleasure-way Excel TS coach battery charging
My 2010 Pleasure-way Excel TS does not charge my coach battery. When on the road, using the refrigerator on DC, the coach battery goes dead after about two hours. Anyone run into this? I am second owner of this unit.
rosco210 is offline   Reply With Quote
Old 02-20-2015, 11:11 PM   #2
Default Re: 2010 Pleasure-way Excel TS coach battery charging
does the alternator charge the battery when when fridge not on 12 volt?.
i think you only have 1 coach battery and a 3 way fridge can use up 100 amps in an hour when on 12 volt. how big of an alternator do you have
Old 02-20-2015, 11:46 PM   #3
Check the charge line breaker reset switch on the breaker. It might have tripped and if so that would prevent the coach battery from being charged by the alternator.
