Old 02-06-2007, 06:39 AM   #1
Default 2007 Sprinter Van on Cars.com
Check it out.....
http://research.cars......
Bob & Sharon
Old 02-06-2007, 05:13 PM   #2
Looks like the diesel engine is standard:
Old 04-05-2007, 09:24 PM   #3
Default Sprinter Agiles in stock
I have noticed on some of the class B forums where people seem to be wanting the new agile, but say they are hard to find. I was at my local Roadtrek dealer this morning for some warranty work on my 190 V. and they have 14 RTs in stock and 2 of the Sprinter Agiles. The dealer is in Galion Ohio, Craig Smith RV and they are really great people to do business with. Hope this helps some one.
Steve & Chris
2006 Chevy Roadtrek 190 V
FMCA #376666
Barman is offline   Reply With Quote
Old 04-06-2007, 02:00 AM   #4
Van City, St. Louis, had 3 earlier this week........
Bob & Sharon
Old 07-31-2007, 06:52 AM   #5
I wonder if the roof air could run off of a massive battery bank or small (quiet) generator?
Details and Technology
The high-performance rear air conditioning system available on Passenger Van is fitted in the front sunroof aperture over the rear compartment. It is driven by its own compressor and has a maximum cooling performance of 14 kW. The roof-mounted unit also extends some way into the interior of the vehicle. The air conditioning system supplements the cooling provided by (automatically controlled air conditioning system), though this boosting function can be independently activated and adjusted. The system operates only in recirculation mode. It is controlled by a separate switch, which allows three fan speeds to be selected, and by a continuously variable temperature selector. The cooled air is supplied via adjustable outlets on the underside of the roof duct. The airflow direction can be individually adjusted and, if desired, the air supply can be shut off completely. The roof duct reduces the interior height of the vehicle. Two or three interior lights, depending on wheelbase, are also integrated in the roof duct. They are switched on and off by the door contact switch or individually at each light.
Benefits and Arguments
• Optimized interior climate in rear section
• Enhanced comfort and well-being for passengers in the rear
• Improved interior air quality
Optimized interior climate due to additional cooling of the air supply to the rear compartment. This system is particularly recommended for vehicles used in very hot climates. Rear passengers can individually adjust the air outlets for improved comfort and well-being. A pollen and particulate filter
improves the interior air quality.
Remarks
Included in available Cooling Group (AZD) on Passenger Van only.
