Old 02-11-2016, 12:08 AM   #1
Default 1998 Roadtrek 190 Dodge 318 propane tank
Anyone any one able to tell me what the propane tank manufacturer and tank model number is for my recently purchased 1998 Roadtrek 190 Popular 318 Dodge would be. The tank on the "Dodge" chassis is a "remote fill" tank located just behind the rear drivers side axle. The tank ID plate is not visible due to the fresh water tank blocking the visual access to the nameplate. Seems like you have to remove the fresh water tank to ID the propane tank ( strange way to install a tank when you cannot see the ID plate) It appears to be around a 10" or 12" diam x 23" long tank. Any help would be appreciated.
Thanks
Chris
chrisu is offline   Reply With Quote
Old 02-11-2016, 12:52 AM   #2
Have you tried contacting Roadtrek to get the info?
Another good source of info on Roadtrek parts is Maureen at Leisure Time RV in Florida.
Old 02-11-2016, 01:33 AM   #3
Will give Roadtrek a call to see if they can ID the tank for me.
Thanks
Old 02-11-2016, 04:58 AM   #4
Manchester tanks
DOT Tanks Propane Tanks Compressed Air Tanks ASME Grill Manufacturer
Caped Crusader is offline   Reply With Quote
Old 04-15-2016, 09:55 AM   #5
Manchester made the tank on the 2001 dodge 192tb class b
behind rear axle
ald2120 is offline   Reply With Quote
Old 04-16-2016, 01:37 PM   #6
Mike's Avatar
Originally Posted by Caped Crusader View Post
Correct. The ASME tanks are built better for service longevity, and are more durable and are typically not included in the 10 years and out rules that govern the portable 20 lb. tanks for BBQ grills and such.
Old 07-21-2022, 12:24 PM   #7
My RT 02ChevyP190 model of the propane tank is Manchester 68001. That number was found in the Owners Manual which you can download on the RT web site. Road Trek referred me to Mobile Life in Canada and Van life in Mississippi. Chris at Mobile Life also gave that number
Floorman is offline   Reply With Quote
