Old 06-10-2010, 11:24 AM   #1
Default 1998 Dodge van cruise control
The cruise control on my '98 Dodge van is not working.
It doesn't set right away. If I fiddle with it a bit (press on/off a few times and hold the button down for a while) it will set but the van's speed will slowly decrease so it is not usable.
Any ideas? Do I have to take it in to a mechanic?
Old 06-14-2010, 02:13 AM   #2
obiewan kanobe's Avatar
Default Re: 1998 Dodge van cruise control
first, check any vacuum lines to the unit. some lines are plastic and may look like wires. check all connectors for corrosion ( pencil eraser and wd 40 to clean). fuses are probly ok since it starts. there is usually a vacuum chamber. newest models may go through computer, if equipped, but, don't think that is a problem.
on older dodge vans ( 1979 1986) i have found the vacuum lines or sometimes binding linkage/ cable to be problem. borrow a chiltons manual or look it up on the web, the parts are all accessable and easy to check.
don't give up too easy, it is usually something simple.
obiewan kanobe is offline   Reply With Quote
Old 07-04-2010, 01:50 PM   #3
Thank you - I do appreciate your help. I will tackle this soon.
