Old 02-10-2018, 08:30 PM   #1
Default 1996 pleasure way - small water leak , rear right side
I have a 1996 Pleasure way. It has a small water leak in the rear right side. Wondering where the first place to check ? Anyone with similar situation or tips would help.
Cheers !
puckitguy is offline   Reply With Quote
Old 02-13-2018, 04:51 PM   #2
Cheers !
Hi,
I have a similar leak in my 2008 TS after a heavy rain I noticed a steady drip from just behind the passenger side rear wheel fender which lasted a few days. I was told it had probably got water inside from the window but not sure as the van is parked on a slight uphill sloped driveway and there were no signs of a leak from inside the van. Recommendation was to drill a small hole to allow the fender to drain from future heavy rainstorms, not really sure if this will do the trick but I guess it is worth a go.
David & Angela
2008 Pleasure Way Plateau TS
Porsche911 is offline   Reply With Quote
