Old 08-06-2012, 10:07 PM   #1
Default 1988 Roadtrek
Help!! Does anyone here have an 88 Roadtrek? I just bought one and the owners manual leaves a lot to be desired. Mainly what I want to know is on the Progressvie Dynamics convertor the circuit breakers & fuzes located in side the trap door are not labeled. One is for the charger circuit one is for water heater (labeled WH) all others I don't know.
Any help will be appreciated.
Bruce
oldcardoc is offline   Reply With Quote
Old 08-07-2012, 12:25 AM   #2
Default Re: 1988 Roadtrek
Hopefully someone with the same model as you will see this post.
I wonder though if two units could have been wired differently ........................ built at different times in the year maybe...............
Probably best to test the unknown breakers by seeing what doesn't work when they are turned off. Same idea with the fuses. Pull them one at a time to see what doesn't work.
On 110v you might have:
water heater
converter / charger
fridge
air conditioner
1 or 2 circuits with 110v outlets
On 12v there could be:
lights
water pump
fridge
fan
furnace fan
propane and C0 detectors
TV antenna amplifier
monitor panel for tank & battery levels
