Old 08-02-2012, 06:49 AM   #1
Default 04/05 Chevy roadtrek 190 Versitile stalls climbing hills
New to this forum; sorry if old Question. We are new to a 40k mi '04 Chevy / '05 Roadtrek 190 Versitile. Recently it has lost power and stalled a few times on long but mild-uphill grades @ 55 to 65 MPH. Altitudes less than 5k ft. Easy restart after stopping, then runs normally. Weather was HOT but oil, temp & voltage gages normal before stall. Was in cruise control when power losses occurred. Is this a known prob? Is it related to the fact that the gas-tank is very difficult to fill: most gas pumps' minimum flow rates cause pump to auto shut-off, requires difficult manual minimum pump squeeze or shut-off/squeeze/shutoff etc. 100 times or more. Are both issues a tank venting prob? Are these Roadtrek modification issues, or a Chevy van prob? Any ideas, please.
Jim Fife
jimfife is offline   Reply With Quote
Old 08-02-2012, 12:15 PM   #2
Default Re: 04/05 Chevy roadtrek 190 Versitile stalls climbing hills
Jim Fife
It could be venting, but not particularly likely. That is easy to test by leaving the cap loose when it starts to act up. Hot weather and high load issues often are fuel pressure related. Fuel pump/fuel filter could be getting weak. You could be getting vapor lock from fuel boiling in the fuel lines near hot areas. Ethanol laced fuels are much more likely to vapor lock than pure gasoline. At 40K, I think I would start with the fuel filter, as it is cheap and easy compared to other things, and is due anyway. Then move on to a fuel pressure test. GM products are also prone to failure of the crank position sensor, which will give you the symptoms you see. It will suddenly quit, but restart and run fine. MOST of time, but not always, they will set a "check engine" code from a crank sensor, as well as problems with other electrical components.
Old 08-02-2012, 06:27 PM   #3
Re: the fuel filling problem
There's been lots of discussion over the years. Some tips I've read are:
find a gas pump on a bit of slope so that the front of your van is lower than the back.
or
Insert the gas pump nozzle then back it out about an inch
or
rotate the pump handle to the right to about the 3 or 4 o'clock position
or
check with a RT dealer about a fix that rotates the fill hose vent to the top instead of the bottom
Maybe a combination of some of the tips...........
I don't ever recall having that problem with my '04 190P.
