Old 10-21-2014, 12:17 PM   #1
Default Underpowered
Took my new 1995 Rialta on its first trip in mountains recently. I felt Rialta were somewhat underpowered when I first drove one and that was on level terrain. In the mountains I was able to achieve only 35 mph on an Interstate locally and am concerned about how the unit will perform on an extended trip in mountains. Is this a characteristic of the Rialta or should I be looking at having and engine overhaul or replacement with a bigger ( 6 cylinder/ more HP )) motor ?
Even travelling on level roads it shows 3000+ RPM @ 55 mph. Is this normal ?
abaniki is offline   Reply With Quote
Old 10-23-2014, 02:29 PM   #2
bigdan's Avatar
I had a 2.5L gas engine in my westfalia , and it felt so underpowered that I switched to a modified TDI engine .....
Some said that I was too speedy lolllllllllll....maybe but that`s the way I am !
personnaly a 2.5L @ 115 hp is way underpowered ....
it is feasible to transfer a VR6 in it ....... but it`s gonna cost !
It`s your decision .....
If you think the Rialta is worth the expense ,
or keep it this way and relax !!!!
Dan
1996 C-21 Triple E ..... 86 Jeep CJ quite modded , 84 olds cutlass resto mod ,
On or off road , I`m on the road ! roadtrips !
bigdan is offline   Reply With Quote
Old 10-28-2014, 01:33 PM   #3
I just don't want to be in the middle of a cross country trip or silimar and have the engine overheat and /or die.
Does 3000+ rpm at 55mph seem excessive ?
Old 10-29-2014, 02:01 PM   #4
mloganusda's Avatar
Your RPM's sound about right for the 5 cylinder engine. The 4 cylinder LeSharo I owned would run about 4K at 60 mph and gave 15 mpg. My 04 HD Rialta, with 24v engine runs at 3K RPM at 62 mph. Driving a motor home with any engine will require torque and does not drive like a car will. Unless you are trying to make time to arrive at a certain destination, take your time and see the country.
Old 10-29-2014, 04:32 PM   #5
bigdan's Avatar
my 2.5L in my westfalia ran at 3300 rpm @ 60mph ..........
