Old 06-08-2015, 01:09 PM   #1
Default New Owners of 2004 Rialta HD
Hello,
We just inherited a 2004 Rialta HD with 37,000 miles on it. It was our fahters, wifes Dad, and he has owned it since new in Illinois. We live in northern Alabama, and he has since moved to be closer to us. He is no longer able to drive long distances by himself anymore, so he said we could have the Rialta if we wanted it. We jumped at the offer. Can't wait to start taking weekend trips and going to Horse events with our daughter.
jtckane114 is offline   Reply With Quote
Old 06-08-2015, 11:51 PM   #2
bigdan's Avatar
welcome ,
youll love it !
it`s an incredible vehicle
Dan
1996 C-21 Triple E ..... 86 Jeep CJ quite modded , 84 olds cutlass resto mod ,
On or off road , I`m on the road ! roadtrips !
bigdan is offline   Reply With Quote
Old 06-10-2015, 09:31 AM   #3
Thanks Dan.
First "Big" drive was from Chicago back here to Alabama. Stopped for night in Edinburgh, IN. Rode great!! Oh, and I was pulling a 5X8 enclosed trailer. Got a litttle windy the second day and fought that a little, but can't do anything about Mother Nature, just slowed down a little and continued on.
Old 06-11-2015, 02:06 PM   #4
bigdan's Avatar
pulled a trailer , ;-(
hope you have a transmission oil cooler .......
necessity even without pulling a trailer
believe me !
Dan ,
Old 06-15-2015, 09:52 AM   #5
I will definitly look and see if I have one installed and get one if i don't. Thanks
Old 07-30-2015, 04:21 AM   #6
Welcome John & Tracy,
The HD is a super floorplan. I have a 1999 HD and most of the vehicle is the same as the 2004. You have more horsepower but the difference is minimal and I have plenty of zip with mine and it does the hills great.
I have a million tips and just about know the unit inside and out. Mine has around 50,000 miles on it so far and still looks new! I made sure all components, drive train, tires, shocks, etc. are original and as per factory specs. I find many Rialta owners not knowing that the front tires are smaller than the rear and have seen a few with them on backwards. People are saying that the Continental Tires are no longer available. I just got a new set last year and had no problem but they have to be the specific ones made for the load of the Rialta. Even though the Eurovan Chassis (Volkswagen) has its own specs you want to make sure you follow the modified specs from Winnebago. Another tip: Use the Cruise Control any chance you get; especially any hill climbing. You will never be able to climb the hills as well if you try it manually. I am an excellent driver but nothing compares with the computeristic shifting that occurs when the cruise is engaged. In most cases I can climb any hill at the properly posted speed and don't bog down. I always had trouble with this before I read a posting on this site about the importance of using the Cruise feature for climbing hills. You may already do this but just in case.
Hopefully, you are familiar with all the other features. They are pretty much like any RV. The bathroom is one of my favorite designs and YES, I use the shower all of the time. It states in the manual that there is a filter for the shower Power Drain feature. This MUST be emptied after about 8-12 showers and you will notice it slows down with the increasing showers. It is a bear to get to in the HD. I moved my filter directly under the wardrobe closet. (That floor comes up with only 3 screws hidden under the edge of the carpet. Trust me: this is easier than contorting under the dinette seat to get it apart, clean it (easy part) and put it back together. Now, I just loosen the screws, pull up on the floor, undo the filter, clean it, reinstall, and you're good to go for another while. If the Power Drain is working properly it should drain faster than you can fill it while showering. I am able to do a reasonable shower without running out of hot water. Note that the shower water goes to the Black Tank. That is a good thing because the Gray Tank only holds 7 gals.
I find the Rialta a most unique and functional design. You get the best feeling of space when sitting on the Captain's Chairs (turned around) and watching TV. The coach feels bigger this way and in time your brain will adjust and it will feel like home. Do you have the optional Oven below the stovetop? I have that and am glad for it because one can't always fire up the generator to power up the microwave if you are not hooked up. Like I said, I have a million tips so I better stop here for now.
All the best and hope to hear more from both of you!
Paul
CGAZ Paul is offline   Reply With Quote
