Old 06-21-2017, 06:09 PM   #1
Default Leaks
I just purchased 2001, 190 rt ,dodge, years ago I owned a 2003, 200 rt chev and had a leak on left side rear window, now I have a leak on same window. Any imput or new fixes, or is it just Karma
Pelicantrek is offline   Reply With Quote
Old 06-21-2017, 09:30 PM   #2
See your location is FL...you really need a fix - with all the rain you been receiving. I presume the leak is around the rubber seal of the window; I would try using Captain Claxton's Crack Sealer. You can pick it up in West Marine or someplace like that. It is a milky white sealant..I would put it in where the seal appears loose and will accept it. It flows easy, and finds the leak and seals it. Someone else might have something better, but I used this on an '05 190P with a leak around the 3 Upper Windows - stopped it, and when the material dried, I shampooed the stain away. Ron
Ron J. Moore
'15 RT210P
