Old 05-17-2020, 11:01 PM   #1
Default Hi from Arizona
My wife and I just bought a 2001 Roadtrek 190 popular on a Dodge. We have rved extensively throughout our lives but as we are getting older it seems that we are continually downsizing rigs. The Roadtrek is a one owner with only 65,000 miles. I’m currently going through it fixing small things and personalizing it. We think we’re going to love it.
Jbell is offline   Reply With Quote
Old 05-17-2020, 11:23 PM   #2
Hi,
Lots of Arizonans here.
lots of roadtrek and dodge owners so suitable answers and hints should be coming your way
1 tip for you is that the RoadTrek ( and my PleasureWay) are Canadian built.
You will see many screws which take a tapered square driver
you can find "square drive" screwdrivers in the States
But my Canadian "Robertson Head" R1 and R2 size screwdrivers fit better
suggest you get some.
cheers!
Old 05-18-2020, 01:38 AM   #3
Welcome to the forum Jbell!
Old 05-18-2020, 04:24 PM   #4
DesertCanuck's Avatar
Welcome aboard.....sounds like you have more experience than I do at this; and yet I am doing fine.
DesertCanuck is offline   Reply With Quote
Old 05-18-2020, 05:30 PM   #5
Jon in AZ's Avatar
Hello from the White Mountains!
2014 Roadtrek 190 Popular
2008 Scamp 13
Old 05-22-2020, 01:57 AM   #6
Default Thanks for the welcome guys
So for I’m happy with the roadtrek. Currently doing a lot of minor maintenance items and modifications.
1. New tires - Hankook LT245/75R16 LRE
2. Removed third seat
3. New toilet
4. Clean carb and new fuel pump for Onan
5. New dump valves and hose
6. ...
And the list goes on. When I finish all this stuff we can take it out and see how we really like it.
Old 05-22-2020, 03:01 AM   #7
typical!
I spent much time in the driveway sorting out how everything works too.
Better in the driveway than in a campground somewhere
Old 05-22-2020, 02:19 PM   #8
Originally Posted by mkguitar View Post
typical!
Or on the side of the road or in the waiting room of a repair shop.
Old 05-22-2020, 02:35 PM   #9
typical!
Both good advice. Spending time testing your rig (even at home) will allow you to discover items that need attention. An added benefit is you will familiarize youself and get comfortable with your rv.
You'll learn something every day.
Old 05-22-2020, 04:52 PM   #10
job 1 ...working the TV !
On our 2006 model we had a small flatscreen with a digital converter and a crank up antenna
at costco i noticed some of the smaller samsungs are 12 VDC native and use a wall wart-
I mounted a 21" samsung for $129
( got rid of the smaller tv and the digital converter box & wired into the DC )
which also has a USB for movies and TV shows I put on a thumb drive
the crank up antenna worked well but wiggled in the wind when driving, I replaced that with a fixed height antenna ( low profile) which rotates
and use the "TVTowers " app to aim the antenna
from my driveway in North Phoenix I can pick up the Tucson stations on Mt Lemmon 108 miles away
Old 05-22-2020, 06:25 PM   #11
That's quite impressive performance for the antenna. Would you care to provide a link? DW loves her TV.
TIA and ttfn.
Old 05-22-2020, 07:41 PM   #12
We have such poor reception (and it seems to deteriorate after sunset) that we carry our home Tivo Bolt loaded up with shows to watch on the road. The only problem is I have to run the inverter which uses about the same watts as the Bolt.
I don't want to make a hole in my roof for a rotating antenna, but would certainly like something with more range than the Sole antenna from the factory.
Old 05-22-2020, 10:27 PM   #13
the antenna is the wineguard rayzar Z1 retrofit, which I adapted to the old crank up mount for the wineguard sensar type- I used a peiece of square stock to do away with the crank up part
https://winegard.com/products/hdtv-d...fit-head-white
the rv has a wineguard antenna amplifer already which I use in line
similar to this-
https://www.amazon.com/Winegard-RV-7...0182592&sr=8-3
mike
Old 05-23-2020, 02:03 AM   #14
similar to this-
mike
Thanks......
Old 05-25-2020, 11:44 PM   #15
Hi from Phoenix and the White Mountains of Arizona
We also have a 2001 190P Dodge. We are the 2nd owners and have had it for over 10 years. We now have 80,000 miles and everything works.
Bob
flynride is offline   Reply With Quote
Old 05-26-2020, 04:59 AM   #16
Good to hear. I hope we are as fortunate as you with our roadtrek.
Thanks,
John
Old 05-26-2020, 05:04 AM   #17
Have same RT on Dodge. Took out 3rd chair and put in a cabinet; more counter space and storage. Replaced all the lighting with LED lights or just bulbs. Put in 400w of solar power, two lead acid batteries and a compressor fridge. These last are the best upgrades of all that I have done. Refrigeration and no worry boondocking have been key for our enjoyment. We never use an RV park. I actually have a hard time seeing how a new van would be more functional; but love the stylish and modern improvements.
Kevin Graves is offline   Reply With Quote
Old 05-26-2020, 06:13 AM   #18
Hi Kevin,
I have already removed the third seat, cabinet to come later. All lights have been replaced with LED bulbs. Added two Battle Born lithium batteries. Installed 2000 watt Xantrex pure sign wave inverter/charger. Solar and compressor refrigerator are on the list next. Still getting all the more minor task finished. We also boondock exclusively in forest, BLM, Natl parks ... Everything is working well so far, even got the Onan purrin. The refrigerator won’t ever work as well as I want in hot weather so that’s why I will go the compressor route.
Thanks for the response,
John
