Old 08-12-2014, 01:24 PM   #1
Default city water hook up
1995 rialta qd
when I turn on the water pump it cysles every 45 seconds or so. It runs for just a couple of seconds. Also when the pump is in the on position and it is doing the above cycling water drips out of the city water hook up junction. Is that normal ?
abaniki is offline   Reply With Quote
Old 08-14-2014, 06:12 PM   #2
mloganusda's Avatar
The cycling of the water pump means there is loss of water pressure. The pump should run and stop after pressure is built up. The leaking of the city water inlet is where you problem is. Try pushing in on the little knob inside the city water inlet, there may be a piece of trash stuck there and keeping the valve from fully closing. Just make sure there is little water prssure when you do this or pressure will keep you from pushing in.
Old 10-23-2017, 04:34 PM   #3
Hi,
I just tried to hook up to city water (at home) only to find water is being blocked somehow entering the RV? I have looked for a shut off valve but can't find one, the fresh water fill and water flow works fine, I have heard that there is a problem sometimes with the inlet valve itself, any help suggestions would be much appreciated. 2008 Pleasure way Plateau TS
Thanks
David & Angela
2008 Pleasure Way Plateau TS
Porsche911 is offline   Reply With Quote
Old 10-23-2017, 05:15 PM   #4
I am not familiar with your model, but you might want to check to see if you have a fine-gauge debris screen somewhere in the transmission line. If you do, it might be gunked up. Believe it or not, those can get fouled to the point where they block water flow.
Here's what ours looked like (this being on the fresh water tank line, not the city line). We didn't generate the poor maintenance conditions that led to this. We bought our rig used, and it came like this. I shudder to think what had been in those lines.
Old 10-23-2017, 05:35 PM   #5
Thanks for the response, our rig was also purchased used but all maintenance has been kept up to a high standard but this just might have been over looked and could very well be the problem (fingers crossed) as the inlet valve has a mess screen which I did not actually inspect.
David & Angela
Old 10-24-2017, 06:32 PM   #6
This is the strainer mounted on the fresh water tank pressurized inline after over 3 years and many refiils.
Old 10-24-2017, 07:47 PM   #7
Yyyyup, it looks like that because George designed, built, and took care of his van. We bought ours second-hand. I have a sinking feeling that the previous owner may have on-loaded pond water or something, because we sucked scum load after scum load after scum load out of that tank when we first got it. Cleaning the little strainer became de rigueur before each trip, or we knew we'd be plugged. And the only way to generate stuff like that is to have an organic matter load, which will not come from tap water. Ugh. I'm just glad it's behind us now.
Old 10-24-2017, 09:00 PM   #8
Thank you,
Your strainer has a brown color deposit, my guess would be that it is from iron sediment.
