Originally Posted by mumkin
All Roadtreks on the Promaster require the inverter to be on in order to charge or use 110v. So, it has been since 2015 up to today.
If the receptacle in your home is a GFCI, it will kick you off. Find a receptacle in your home that is not GFCI. Turn everything off in the van... turn on the battery disconnect... turn on the inverter (on the remote switch... never with the switch on the inverter) and then plug in. This has been the instructions since 2015.
The GFI reset in the van is very difficult to reset. The switch must be turned on and off... sometimes two or three times... and it is a real finger breaker to do so.
BTW... I have never heard anyone over on the Zion FB page mention issues with an "automatic transfer switch." I don't even know what that is. lol
If inverter needs to be on that means automatic transfer switch (ATS) is inside the inverter. ATS senses incoming AC power, if shore AC power is present, it switches inverter outputs to shore AC, if there is no shore it switches back to the inverter.
ATS devices we commonly use with generators as a separate component, work similarly - with shore present outputs were switched to shore power and without shore power back to the generator.
Most quality inverters have these ATS devices built in, hence invisible.
