Old 02-19-2018, 08:35 PM   #1
Default 2016 Itasca Viva LED ceiling lights
Has anyone had problems on led inside the coach. Mine its the led light behind the drivers side by the dining area that keeps loosing contact, and when I take the cover off and touch the led bulb gently it comes on for awhile then out again. What could be wrong? I tried tightening the small screws around it thinking it might just be loose. But still it keeps doing it.
Lex Mallari is offline   Reply With Quote
Old 02-19-2018, 09:28 PM   #2
mloganusda's Avatar
You might remove the whole light to check for loose connections of the wires. Could be the ground wire.
MLogan
2017 23D Trend
Smyrna, TN
Old 02-19-2018, 10:04 PM   #3
Thanks I really was avoiding to do that, but you’re abdolutely right. I’ll take the lights off, and check thewires.
Old 02-19-2018, 10:06 PM   #4
I was trying to avoid to do that. You’re absolutely right, I should take out the light and check the wires thanks..
