Re: Garmin basecamp
I finally tried it, and I guess it would be a decent replacement for MSN's trip mapping software, although I'm going on what it could do based on the comments of others. I have never used S&T or Basecamp before.
I guess I'm thinking using something like Basecamp, to me, is like doing the Garmin's work for it. I'm happy using the nuvi in a much more ad hoc manner, and adding an occasional Via Point (which ARE ignored if you miss them, as I found out this afternoon), or a specific interest POI file, if we want to stop at something we've never seen before, and it's somewhere near our primary route.
So, I'm not sure Basecamp or similar route planning software use is in the cards for us any time soon.
It does look cool, and it's fairly easy to use, although there are still some things about that annoyed me, like having to drop the little hand to pick up the pencil, and stuff like that. Having to use the compass points and click to move the map while trying to find waypoints was also a bit tedious.
If you like that degree of detail in your trips, then it looks like a good trip planning tool. Lots of user defined and default options, for sure.
I do have an extensive "Extras" folder on my nuvi filled with lots of "Custom POI" files that I've gathered over the last 3 years, and coupled with the Proximity Alert" audible warnings, it sort of tells us when we're near something that might be of interest to us. I get most of that stuff from POI Factory, or directly from some commercial websites. Some retailers are actually clever enough to realize that if you give people a POI file with all your locations in it, that can be loaded into their GPS unit, they might actually find you more easily, and spend some money at your establishments.
