Old 09-03-2021, 03:29 PM   #1
Default dicor
The tv antenna is leaking into my 2018 Travato. Bought black dicor and went on the roof to seal the antenna. Someone had put white dicor over and around the black dicor on the tv antenna some time in the past. My question is can I put black dicor over the white that is on top of black dicor to try and seal the antenna?
CKTravato2018 is offline   Reply With Quote
Old 09-03-2021, 03:34 PM   #2
Hi: I have 2016 PW Lexor. I check my roof brackets. Use Dicor to reseal screws and brackets. Just use the same color.
I think you should be fine using Dicor of different color. Just make sure, you clean old stuff well. If lose, scrap off lose stuff. Clean remaining bonded material very well with isopropyl alcohol. Apply and allow to set.
Old 09-03-2021, 05:08 PM   #3
if you have a crank up rotating antenna, there is a seal in there
youtube will show you
