Mark here is a picture of the dual battery tray I made up to go under the chassis near the rear steps. The bolts you see on the frame are only there to hold the tray flush, on top the angle iron hooks over the frame to support the weight of the batteries. I only have one on the tray at this time but two deep cycles will fit. You will note that I also have the automatic water filler ( works great)
