Wiring panel for 2001 RT 190
Trying to diagnose my Dometic fridge so checking fuses.
Here is the fuse arrangement in the wiring panel on my 2001 RT 190.
I have no manual or wiring diagram, so am trying to figure out if the fuses on there are what they should be (i.e. right amps for the right circuit).
Circuit 6 is left blank for some reason.
I attach a diagram for a 1996 Roadtrek I found on the net, which shows the fuse amps and labels for the 8 DC circuits. So I can figure out what some of my circuits are for, even though the arrangement is very different.
1996: 1 - 20 - 15 - 1 - 15 - 10 - 10 - 15
Mine: 10 - 1 - 20 - 15 - 15 - x - 1 - 10 - 15
1996 labels in diagram, left to right
CO Det (1) Lights, Furnace, Hood fan (20), Water Heater (15), LP Det (1), Fridge (15), Roof Fan (10), Water Pump (10), TV (15)
I suppose I can reverse-engineer mine by taking out a fuse and see what does not work (other than the fridge).
Just looking at the amp numbers, I would think the arrangement on mine is (left to right):
(10); CO/LP Det (1); Hood Fan (20); (15); (15); x; CO/LP Det (1); (10); (15)
Just need to identify the three 15 A circuits by trial and error (fridge will be one of them), and same for the two 10 A circuits.
Then properly label for the next poor schmuck who needs to figure this out LOL
Anyway, I share in case this info if of use to somebody.
Thanks.
2001 Dodge Roadtrek Popular 190 - Proudly Canadian
