Old 03-06-2017, 12:20 AM   #1
Default Where is the fuse labeled radio 3003 RT 190
Hello again all... my other question of the day is the location and label of the Radio Fuse for my 2003 Roadtrek 190. Due to the parasitic drain from the stock radio it is advised to remove the fuse when the van is just sitting. My fuse box is under the drivers seat and there are many labeled fuses there. But I cannot see any labeled Radio/RDO . Does anyone know is this fuse joined with another thus why not labeled. Everything in the Van is original. If anyone can confirm the location and name of the fuze for 2003 model I would appreciate it
Thanks for the help on this issue.
Buggybumpers is offline   Reply With Quote
Old 03-06-2017, 12:22 AM   #2
Sorry 2003, ignore the 3003 year... bad fingers
Old 03-06-2017, 01:08 AM   #3
which chassis?
my 2005 chev has a fuse box under the drivers seat for some stuff, but my radio fuse is under the hood in the main fuse box
I have a switch on my battery just for your same reason- just as easy.
as the alarm and the speedo cluster also pull power when the van is parked
Old 03-06-2017, 01:59 AM   #4
Hi thanks for the reply... its a RT 190 2003 on the Chevy Chassis. When you say under the hood is that outside under the hood or inside underneath where the OBD port resides?
thanks and appreciate where exzactly the box is under the hood..
thanks
Dan
Old 03-06-2017, 02:57 AM   #5
on my 2005 the large fuse box is under the hood ( or bonnet if you are English).
standing at the front of the vehicle, the fuses are under a large rectangular plastic cover on YOUR right side which is down about 12" there may be hoses or cabling in the way.
the backside of the cover has a legend as to which fuse does what
Old 03-06-2017, 03:05 AM   #6
Fantastic... thank you for the info... will look at first light!!! Appreciate your help
