Old 01-24-2020, 04:38 PM   #81
As booster and hbn7hj have stated, you can definitely add a DC to DC charger that isolates your coach and engine batteries from one another yet charges your coach batteries off the engine alternator. Limiting current to 40A is a good idea and would be adequate to keep coach batteries charged without over-taxing your engine alternator.
However, have you verified with Coachmen that your rig doesn't have this feature? Pretty standard to have alternator charging. In fact, I've not heard of a modern rig that doesn't. If you're not getting charging now, could there be a loose connection or blown fuse?
If you can gain access to your power center (where your inverter resides) and post some photos, I'm sure someone here can identify if you already have an isolator in place.
Good luck.
Old 02-19-2020, 04:14 PM   #82
engnrsrule's Avatar
Originally Posted by Jon in AZ View Post
100% charge from shore power at home before trip.
Partial recharge (~25%) from engine alternator during day trip away from camp.
Full recharge from engine alternator on drive home.
No solar or generator .
Lights, bed, awning, and recharging electronics only. Cooking and refrigeration on LP. No heat or A/C needed. 2@6V GC2 wet cell
Never went below 2/3 on the battery monitor.
This was our first trip (6 days) and we’ve got a lot to learn yet! Couldn’t figure out how to work the TV via the inverter so we played scrabble instead. Win-win.
Jon, this was the quote I was referring to...
