Modified Sine Wave - cost less,
Pure Sine Wave - cost more, better for electronic items and microwave ovens etc.
Just braining through things here, but seems to me that heaters and motors would be fine with the MSW, but things with transformers in them, i.e. older microwaves, VCRs etc, might be a bit down on voltage because of more heat generation in the transformer, whereas newer stuff with it's own inverter PSU in, will tend to cope with anything vaguely AC-ish. I guess a hint is to read the sticker or box, if it says something like 90-240V 50-60HZ then it probably copes pretty well, but if it is more narrow, say 110-115V 60Hz then it might not be so happy with it.
Other than that I think you'd see most problems when the internal PSU of the device is "strained", i.e. when you've got it in maximum consumption mode. For a TV for example, this might be when you have the volume and brightness maxed.
