Old 07-13-2023, 09:23 PM   #1
Default UHG or standard Generator?
We are looking at 2 slightly used Promaster vans. One is the Zion with the UHG and 2-200ah lithiums, the other is a Legend with standard gen and 2-150ah lithiums. We’ll be using the unit for the usual weekenders, a week here and there and a planned 3-4 week cross country trip next year.
I’m no stranger to camper trailers and generators. I currently own 5 gens with one of them being a new Generac 2800I (suitcase style like the small Hondas).
The floor plan in both are identical with the exception being the one with the standard gen is much more refined and just looks a lot more modern and stylish. Read as…..wife like interior better! LOL
My question is and putting interior aside, if you could pick a one with a UHG or a standard gen for the described intended purpose, which would you prefer?
We will be running the ac quite a bit as we’re in the south.
Thank you everyone for your opinion and/or suggestions.
PS……I already know to keep the wife happy or it really wouldn’t matter which one I pick! I’d still be miserable! 🥴
RLSmith4602 is offline   Reply With Quote
Old 07-13-2023, 10:13 PM   #2
Interesting dilemma? Both battery banks are on the small side 200-300ah. So not much running on batteries. Running your AC will be from your car or generator. Lots more gas running from auto motor. I have read the Promaster does not like to be idling for long periods of time. Personally, I would prefer to use a dedicated generator to run the AC. Unfortunately, some places do not allow running either the auto engine or a generator past 9:00pm?
2016 PW Lexor TS
Old 07-13-2023, 10:30 PM   #3
I’m assuming the places with quiet hours would be campgrounds with most having hookups? Which in that scenario I’d use shore power.
I guess I’m just mainly trying to decide which would be better for our style and climate. I love the idea of a UHG but I’m thinking it wouldn’t serve us well in hotter climate running the ac.
Old 07-13-2023, 10:34 PM   #4
UHG is great if you want to run the ac while driving. Good for pets/kids in the back. But a generator can also be run in the back to power the generator if you want. I have the Onan 2800i quiet generator. I can run it to power the AC if necessary. Although I generally will run it to charge the battery bank and exercise the genny. UHG is great if you are driving a lot.
2016 PW Lexor TS
Old 07-13-2023, 10:37 PM   #5
Not sure that is true. There are lots of variables, but all the numbers I have read suggest that consumption is pretty similar for an Onan vs idling. People usually report <.5 gal/hour for both.
Old 07-13-2023, 10:41 PM   #6
I have seen the same thing when I have looked for information. Might be different is you have a high idle setting.
Even at idle most of the UTGs will charge lithiums faster than the regular generator will because the generator has to go through the shore charger and you are limited to its output.
Old 07-13-2023, 10:41 PM   #7
Would I be correct in assuming the Onan would be better for ac use at night if boondocking where no quiet hours are in affect?
Old 07-14-2023, 01:12 AM   #8
If you want to use the rv for summer rest/roadside stops for lunch, nap you need something powerful to run the ac. That said, you probably wouldn't do that a whole lot.
tarp is offline   Reply With Quote
Old 07-14-2023, 01:34 AM   #9
Urlauber's Avatar
There are pro's and con's, and you just have to decide which fit you better.
Noise-wise, I would think the UHG has the edge. Also, maybe it takes up a little less space.
On the other hand, the generator is probably a bit more efficient in running the AC than idling the engine. We did some calcs before and the generator came out ahead.
Also, running the engine creates more heat than running the generator. I think.
Some cars should not idle excessively, I believe the diesel Sprinters are among them, while the gas engines tend to care less.
I'd say with a larger battery bank and more driving (in general) the UHG may be better. With a smaller battery bank and more boondocking the genny may win out.
Me, I went with a small battery which has no chance of running the A/C, and a genny that does. I rarely run the A/C, but sometimes it is absolutely needed.
Old 07-14-2023, 02:00 AM   #10
Both of those banks are going to be on the small side for running much more AC than a couple of hours a day off them unless you are driving very soon after and for quite a while.
The big downside of using the engine generator to recharge after using AC is the time it can take, even at the very high charge rate they will give.
You will probably be using around 100 amps when the compressor of the AC is running, so for every hour of compressor running AC you need to replace 100 amp hours of charge. From what we have seen most engine generators will net about 165 amp hours per hour of driving. A bit over 35 minutes of driving time. If you use 300 amp hours you are looking at about an hour and 45 minutes. I think in the south it would be easy to get over 12 hours of run time per day so you would need 1200 amp hours which is a lot of batteries. You would be idling the vehicle a lot to keep yourself cool.
IMO, if you don't need to run AC on batteries more than at a rest stop or while you are in shopping, the engine generator and a moderately large (400ah+) battery bank is great, but if you need 24/7 AC about the only choice is a generator or shore power.
Old 07-14-2023, 01:57 PM   #11
You can't run Sprinter diesel UHG for more than 2 hours unless you drive 30-40 minutes inbetween the running for another 2 hours. Obviously that is not an overnight situation unless you have battery power. The run time is not because of the engine but for the emission particulate matter. As far as running, a diesel engine lasts longer than a gas engine in other aspects for your lifetime calculations. Plus, you need to rely on your engine to get you somewhere which is more critical. UHG have a belt from the engine alternator and separate electrical system so is not much burden on the engine as it isn't critical to the engine. A separate generator is another internal combustion engine that takes up more critical space in a small Class B vehicle and has way more separate maintenance issues.
My UHG produces 220ah at high idle and 270-280ah at highway speeds dedicated to the coach only. The engine alternator is for the chassis and in Sprinters provide 40ah regulated for the coach. To recharge the same amount of coach batteries, you would have to drive at the 7 hours to 1 hour. I can recharge a day's stay of battery use in 30 minutes sans the use of air conditioning. As I previously mentioned you cannot depend on solar. Battery power is way more important especially with an UHG and no UHG or generator if boondocking without air conditioning may be an eventual drain on your batteries that you can't replenish, in a day's driving especially with an extended stay.
Some companies are providing the 48v Volta high capacity battery system with an UHG that produce an equivalent 12v to power overnight air conditioning. ARV has gone a step further with their own 48v system that provides more power. I don't need it as I avoid air conditioning almost always.
With more coach battery (needs to be lithium) with UHG, you can eliminate all propane use, generator and solar. That's a lot of space, weight and maintenance taken up that is eliminated. A separate coach generator is old school and as I mentioned, you would be a pariah where you park overnight without shore power or boondocking near others if camping in a campground situation or on a residential street, driveway, or parking lot not running a generator. How many times are you boondocking in a NF, BLM land or on the beach alone? In your dreams. Seek shore power if you want to run air conditioning overnight.
I can't help people with older Class Bs that can't be adequately converted, people living in the south, people with special health needs or stay-in people not enjoying the outdoors unless they are buying a new van because most older vans are inadequate.
Old 07-14-2023, 02:28 PM   #12
We have 900 aH of lithium and a second 250a alternator so we haven't needed a generator yet, but I wonder if one solution is to buy one of the little 1500-2000W suitcase generators. They're quiet, light, and don't take up much space. It's not something I would typically carry but maybe it's something worth buying for the one or two trips a year where it would be handy. Next month I plan to spend a week boondocking near a river I want to fish. My batteries will last 4-5 days just running the fridge, lights, etc, but it will be hot and muggy so I might want to run the 12V AC for a few hours in the evenings. My AC pulls about 60 amps when the compressor is running. I haven't actually measured the compressor duty cycle but it seems to be 50% or less based on how often I hear the condenser fans running. So it would only take an hour or two per day to keep the batteries topped off and I wouldn't have to run the van's engine. And I could leave the generator home when I don't need it, which would be most of the time.
Punkinhead is offline   Reply With Quote
Old 07-14-2023, 10:14 PM   #13
The Onan 2800i is pretty quiet. Probably less noisy than most AC units
2016 PW Lexor TS
Old 07-16-2023, 03:14 PM   #14
The Promaster doesn't much mind idling. I have friends who have idled all night to run the AC with the minimal Zion lithium banks and UHG (not the newer larger RT banks).
Personally I strongly prefer the UHG as I have an intense loathing for Onans... lol... based on my past experience, but you are experienced and can probably work on them yourself. I liked the fact that the UHG doesn't need service with the weak spot being the Balmar controller.
That said, based on your needs and experience... and your wife's preference... go with the Onan model.
2015 Roadtrek 170
2011 LTV Libero
2004 GWV Classic Supreme
Old 07-16-2023, 03:59 PM   #15
Originally Posted by mumkin View Post
<snip>
<snip>
What is the Balmar problem? Hadn't heard about that before.
Old 07-16-2023, 08:31 PM   #16
I have a Promaster. The scan gauge indicates .59 to .62 gph when idling. The Onan 2800i burns about .48 gph on full power output. My AC uses 1400 watts when running on its highest setting. During the night, AC will likely cycle on and off so not running full out. Lets assume it runs at 10amps(1200 watts) continuously. That would be less than 1/2 power of .24 gph. So in my opinion, much less fuel to run AC from genny.
2016 PW Lexor TS
Old 07-16-2023, 08:53 PM   #17
That sounds way high for idle consumption.
Assume you get 18mpg at 50mph, then .62 gallon per hour would get you you 31 miles. Using that much sitting still?
Old 07-16-2023, 10:43 PM   #18
Just telling the reading from my scan gauge. The 3.6 liter engine must burn more fuel than the Onan 2800i? It seems if the Onan 2800i single cyclinder is burning .48 gph at full power. The Promaster 3.6L at idle of 800rpm would be much more? I do not know if one could get 31 miles with .62 gallons. Mathematically yes but there is acceleration, etc. Assuming one was already going at 50mph and metered out .62 gallons, probably doable?
2016 PW Lexor TS
Old 07-16-2023, 11:19 PM   #19
My 18mpg was allowing for all that as others report mileage in that range. At a steady 50 mph on level ground I would bet a Promaster would get closer to 22-25mpg steady state.
Is your Scangauge set with all the correct settings? Engine size, number of cylinders, etc. They don't physically measure the fuel flow, they are calculating it from the injector pulse width, injector size, fuel pressure, rpm.
Old 07-17-2023, 08:06 PM   #20
Urlauber's Avatar
Huh... I thought they are just reporting the OBD2 data.
