Old 12-15-2021, 09:53 PM   #1
Default Trouble with Half time oven Apollo 34 series
I have an 2011 Roadtrek SS Agile with a 34 Series Apollo half time oven. While doing a winter run of my generator today I put a cup of water in the micro to give the generator some load. It heated for about 10 seconds and then shut off displaying the "service" light. It will not run at all now, although there is power to the unit and lights and buttons on the keypad function. I tried flipping the breaker and this didn't work. It appears Apollo has gone out of business. Does anyone have any ideas on what the problem might be and/or a recommendation for a replacement oven?
GaryG is offline   Reply With Quote
Old 12-15-2021, 10:09 PM   #2
Hi: A very common problem when microwave no longer heats. It will likely be the magnetron. This is the piece which provides the radiation to heat up food/liquids. I do not know where they can be purchased? You may just want to replace since the magnetron tend to cost as much as new microwave?
Best of Luck!
2016 PW Lexor TS
