Old 11-28-2015, 03:12 PM   #1
Default Trimetric question
Quick question about installing a Trimetric monitor. If I have one large gauge wire between the shunt and the house battery banks and all other grounds and including a chassis ground are on the other side of the shunt will that capture all input and output from the house battery banks?
An example: I have one LED light in the rear that has a positive lead but the ground lead is attached directly to the chassis. Will wiring the Trimetric as described above capture even that small load?
I think the answer is yes but want to make sure.
Old 11-28-2015, 03:19 PM   #2
The answer is "yes".
If the shunt is the ONLY item connected to the battery negative terminal, then all current flows through the shunt and you are fine.
Old 11-28-2015, 03:33 PM   #3
That's great. It's going to be much easier to install than I first assumed. All (I guess I should say most) of the typical house load neg wires, solar included, go to common buss bar that I installed when I did the major electrical upgrade a few years ago.
It looks like buss bar main wire, chassis ground & inverter neg on the other side of the shunt.
Trimetric, Samlex 1500W, some 2GA all to be installed ............. guess who's online garage sale I visited?
Old 11-28-2015, 08:06 PM   #4
Best Converter??
Old 11-28-2015, 09:04 PM   #5
RVelectronics R US??
Old 11-28-2015, 09:04 PM   #6
EBAY????????
Old 11-28-2015, 09:05 PM   #7
Amazon????
Old 11-28-2015, 09:06 PM   #8
Suspense is killing me!
Old 11-29-2015, 01:18 AM   #9
Sorry, I've been out all day.
Booster was upgrading his RT so I bought some of the parts he took out of his van.
The Trimetric will replace the little watt meters I have and the 1500w Samlex should be a nice upgrade.
Old 11-29-2015, 02:30 AM   #10
Forgot about Boosters garage sale. Did you see any leftover "Prince" albums?
Old 11-29-2015, 03:14 AM   #11
Maybe, not sure. Thought I saw something purple
If I was there I'd have been too busy looking at the Magnum inverter and the Lifeline batteries installation.
Old 11-29-2015, 02:47 PM   #12
I think you would have to go to davydd's house to get the purple stuff. He lives much closer to the source!
We also have a purple football team and an uncompleted $1B purple stadium that you could probably get if you really tried.
Old 11-29-2015, 04:16 PM   #13
I'm just 2 miles due north of Prince's Paisley Park recording studio but he has never invited me to one of his middle of the night jam sessions.
