Old 08-08-2016, 06:12 PM   #1
Zia
Default Travato Salenoid location
Having charging problems, but can't locate the Solenoid location in my unit
Zia is offline   Reply With Quote
Old 08-08-2016, 06:18 PM   #2
In a metal box by the rear axle.
James and Stef
Follow us on our blog
https://www.thefitrv.com
thefitrv is offline   Reply With Quote
Old 08-08-2016, 06:38 PM   #3
Default Drawings
w.winnebagoind.com/diagram/2015/15_259g_wire.htm
There are several of us experiencing this issue.
The above resource site will show the location of the DC switch gear.
I have replace the 50 A auto reset breaker, yet the problem persists. I am now going to replace the relay on the DC disconnect to see if a better relay will perform more reliably.
WGO tech support is helping me through the issue. local dealer is having a hard time recreating the issue, but is helpful.
riplips is offline   Reply With Quote
Old 08-08-2016, 07:39 PM   #4
Zia
Cant find it....any other location?
Old 08-08-2016, 09:11 PM   #5
G or K? Not sure it makes a difference, but my location is for a G.
James and Stef
Old 08-08-2016, 09:43 PM   #6
I was told my link was bad:
Wiring Diagrams
Old 08-08-2016, 11:22 PM   #7
Zia
Default Solenoid
Is this what it loks like?
http://rezosystems.com/demos/17338.jpg
Replaced th battery (Bad Cell) and tested with voltage meter, we are getting 14+ volts to the with the engine running to the terminals, so I assume that means the solenoid is fine.
Old 08-09-2016, 08:27 PM   #8
That is it. Interesting that it's not protected. Ours (a '16) is in a box.
James and Stef
Old 08-09-2016, 08:54 PM   #9
a box would be nice, but the solenoid on your starter is similarly exposed.
charging issues, solenoid, travato
