Old 05-08-2018, 10:52 PM   #1
Default Sprinter Starting Problems
I have been reading on F/B of Sprinter owners having to start their engines every few days to keep the battery charged. I read where some folks are purchasing the Trickle Start to handle it. What is so different in the Sprinter that mandates this? I can't imagine storing it for months....better carry a portable jump start. Thanks, Ron
Ron J. Moore
'15 RT210P
Old 05-08-2018, 11:01 PM   #2
Fake news. Sprinters (or at least mine) are no better or worse than other modern cars with lots of electronics. You can't go for months at a time, but every few days is nonsense. Additionally, Sprinters have a very handy ground disconnect feature (down by the accelerator pedal) if you DO have to park for months. Takes 10 seconds.
That said, I do now have a Trik-L-Start. Cheap, easy, and very effective. Well worth it if you park outside and have solar. Takes the whole issue out of the equation. Only really matters over the winter, though.
Old 05-09-2018, 12:31 AM   #3
Thanks Avanti. Like I said, all I know is what I read from folks on F/B, and knew we have guys here who can tell me the straight scoop. Ron
Ron J. Moore
'15 RT210P
Old 05-11-2018, 06:53 PM   #4
I agree. It is not the Sprinter but the battery. I once had my battery go bad (after about 6 years of use) and I couldn't get the Sprinter diesel to jump off. Had to replace the battery before it would start. I keep a smart charger on it at all times it is in storage.
Douglas O. Culpepper
docman5 is offline   Reply With Quote
Old 05-11-2018, 07:33 PM   #5
Only time I had an issue was when I left something plugged into cigarette lighter & drained the battery. Other than that, i’ve had mine set for 2-4 or more weeks with no problem. When not in regular use, I store indoors & use a trickle charger to keep it up, but as I said, with out the charger I have still had no issues with it setting for a few weeks. My guess is people have something on or plugged in like I did, & don’t know it.
OldKansan is offline   Reply With Quote
Old 05-12-2018, 01:56 PM   #6
Default My process
I store my RS away from my home without shore power for weeks at a time and in summer have not had an issue. I make certain the coach power switch is off and no other parasitic drain is on. On occasions I pull off the ground to the battery isolator which is the biggest parasitic drain I have on my rig. If during winter or if for longer periods of time I disconnect the vehicle battery with the "switch" near the accelerator and the coach batteries with a switch I installed.
Gary Mn is offline   Reply With Quote
