Old 05-07-2021, 11:51 PM   #1
Default Solar fuse help
Hi,
Just got a basic 100 watt solar panel kit from HQST. Looking for help on a couple of fuses. One will be 30A between the charge controller and the battery, the other 10A between the solar panel and the controller. If you have any specific recommendations for in-line fuses that will work, I would appreciate the help.
graywolfkayak is offline   Reply With Quote
Old 05-08-2021, 04:43 AM   #2
Boxster1971's Avatar
Fuses are just a pain. I used a 30A DC 187-Series circuit breaker from Blue Sea Systems. They are resettable and can be used to shut down system for maintenance if needed.
https://www.bluesea.com/products/cat...ers/187-Series
Old 05-08-2021, 12:08 PM   #3
eric1514's Avatar
I use these.
LINK
I like that I can disconnect the panels by just pushing a button.
"Il Travato Rosso"
2015 Travato 59g
