Old 08-15-2020, 04:24 PM   #1
Default Silicon Dioxide Batteries
While researching AGM battery options for our RT, I came across silicon dioxide batteries being advertised as an option for RVs. Are they an option, and if yes, how do they compare to AGM batteries?
Sensfan is offline   Reply With Quote
Old 08-15-2020, 05:22 PM   #2
Looking at their website, it appears they go heavy on alternative types of batteries with silicon dioxide, carbon lead, and carbon foam styles. Literature they give is full of all the same type of misleading hype and calculations which have permeated all battery sales pitches these days.
I could not find anything on charge profiles, especially if they address the very long final top off portion of the absorption stage in AGM charging. Also what is the criteria to judge a full battery, time, volts, amp hours,etc?
They also claim 93% charge efficiency, but don't say if it varies over the charge cycle. The 93% would indicate that they are wasting energy charging like the other lead acid batteries, but they claim the don't heat up, so I don't see how both of those can be correct.
The are heavier by 10% than AGM, so big downside for those with big banks and weight concerns.
Long life claimed, but not yet proven in real life, like all new tech batteries.
Bottom line for me is that it is interesting, but would need a lot more information, I think, as they certainly aren't inexpensive.
Old 08-15-2020, 05:45 PM   #3
This is old technology, more robust and good for cold climate, it is called Lead Crystal, Silicon dioxide - Si02 or crystal.
A new comer is lead acid battery with electrode structure based on silicon wafers. Time will tell how successful the are going to be.
https://www.gridtential.com/silicon-joule; https://www.prnewswire.com/news-rele...301082149.html
Old 08-15-2020, 06:58 PM   #4
Thanks booster and GeorgeRa.
