Old 04-21-2023, 02:17 PM   #81
Pete, Thanks for the pic and info. That confirms that all is stock on my RT. I don't like leaving any outside doors/drawers open, that is why I am thinking of re-locating the plug. Not only that, the current cable is really loose when plugged in.
2005 Roadtrek 05C210v
2020 Can Am Spyder RT Limited
Bangorbob is offline   Reply With Quote
Old 04-21-2023, 02:34 PM   #82
Mine is a bit loose also. Perhaps I should replace or get a Smart Plug.
Would be an expensive change as I would also need a 120v adapter. Another $175 on top of the initial $150-250. That seems like a bit much to me.
https://www.rveparts.com/products/sm...RoCHmEQAvD_BwE
Old 04-21-2023, 02:39 PM   #83
I bought this from Amazon. SmartPlug B30ASSY 30-Amp Inlet Connector Combo Kit. A little pricey but I think in the long run it will be worth the $'s. At least I know I will have a very secure connection.
