Old 07-16-2016, 12:42 PM   #1
Ric
Default Second battery switch
My Chevy G30 has 2 batteries, one in the engine bay and the second one approx under the driver seat.
I just bought a battery isolator switch and I want to separate the two batteries when the engine is off or when camping. The second battery -disconnected from the first one- will provide me the electricity to the 12v sockets and to an inverter, without dropping the first battery. The second step will be to add a solar panel that gives power to this batter, for the long stops or holidays.
My question is, are there any "don't do this way" recommendations?
I know I can't drop all the power from the battery, so I have a volt indicator connected
Ric is offline   Reply With Quote
Old 07-16-2016, 04:24 PM   #2
There's so many ways to do stuff.
I'd recommend focusing on the basics like making sure you have really good low resistance connection points. That means no corrosion / oxidation, good crimps. Also, use adequate or even better than adequate wire gauge to minimize voltage drop and maximize current carrying ability.
A bi-directional automatic relay might be had for the same or lower cost than a typical isolator. Isolators typically cause some voltage drop which makes it more challenging to get the house battery fully charged. I'm pleased with the low cost relay I posted about here: http://www.classbforum.com/forums/f8...lled-3409.html
