Old 02-21-2021, 09:32 PM   #21
I just ordered one, have not recieved it yet just hope it's correct.
https://odmrv.com/catalog/index.php?...oducts_id=1243
gobike is offline   Reply With Quote
Old 02-22-2021, 04:09 PM   #22
Originally Posted by 70fit2adventure View Post
I have a 1995 roadtrek 170P and can't find where the switch is located for this outside porch light. Any ideas
on my 2012 170 it's located above the inverter switch.
DRich is offline   Reply With Quote
Old 03-03-2021, 11:27 PM   #23
2005 Chevy 190 - removed the old porch light - even with a brighter LED bulb, it was pretty anemic and the light was not well dispersed. Had a hard time finding a replacement that was tall enough to cover the hole from the original light. Wound up with a motion sensitive unit: https://smile.amazon.com/dp/B00UO6HP...V4KT5Q97DCS0T3. I really like it - you can change it from being a motion light to being switched manually on/off. Covered up the old hole perfectly, and almost too bright.
- Steve
'Blue' 2004 Chevy Roadtrek 190 Popular
rauscs is offline   Reply With Quote
Old 03-08-2021, 01:06 AM   #24
Default Light Replacement
I drilled out the rivets, removed the original fixture, used crimp on splices to connect a new LED fixture to the original wiring, drilled holes for the new fixture, applied silicon chalk to the back of the fixture, screwed it into place, and it has worked perfectly for two years and counting.
Cold Gold is offline   Reply With Quote
Old 10-05-2021, 04:09 AM   #25
Originally Posted by Deano View Post
Has anyone that has an RT with the useless porch light, removed it or opened it up?
Mine is riveted in place. I want to temporarily move it to see if I can access the wiring for a useful LED light that would be mounted just to the rear of the OE light.
Before doing so, I wanted to see if I could get information that may be helpful.
Actually I need a cover for my porch light, does anyone have one?
smtihst is offline   Reply With Quote
