Old 10-17-2015, 12:34 PM   #1
Default Roadtrek Ecotrek and Voltstart
New topic to discuss Roadtrek's Ecotrek and Voltstart
Other topics with Ecotrek, volttrek & voltstart info:
http://www.classbforum.com/forums/f5...trek-3609.html
http://www.classbforum.com/forums/f5...ange-3789.html
and a bit here: http://www.classbforum.com/forums/f5...blog-3678.html
I think a new topic about Ecotrek and Voltstart will help make the info easier to find.
Old 10-17-2015, 12:41 PM   #2
Are there any Ecotrek units out there that are working (not back at the dealer or factory for repairs)?
Old 10-17-2015, 05:09 PM   #3
as you know i keep track of this.however i can only know from people who post on facebook.
I'm sure there are people who have it that don't post so we don't know.
I do know 2 people who have it that we don't know about.
one got an ecotrek 800 2 weeks ago and has not commented.
one picked his up yesterday.
other than those i know of no one who has not had issues that we know about
Bobby R. Jones who had posted some success in his re-start has now had total melt down and his zion has been back at dealer since last monday
Old 10-17-2015, 10:10 PM   #4
Hal Callaway has just posted. he got ecotrek 800 yesterday.
He has gotten Voltrek to work.
it appears for voltrek to work no doors can be opened and hood can't be open.
Old 10-17-2015, 11:35 PM   #5
Makes sense that doors and hood need to be closed for Voltrek to work. The engine is running, after all. And that's an invitation to bad guys.
A 2014 Ocean One MB Sprinter by Advanced RV named "Imagine"
mikes47 is offline   Reply With Quote
Old 10-18-2015, 12:04 AM   #6
and yet it was info no one knew until now. it could have been the issue for some
it's the sliding door i learned
Old 10-18-2015, 01:14 AM   #7
success from hal callaway.
i copied
Hal Callaway My today test results was about 4.5 hours before it was restarted by the Voltstart. I had the interior lights on and the AC temperature set for 55 degrees. You could hang meat in there!!!
Old 10-18-2015, 01:23 AM   #8
wincrasher's Avatar
hmm....4.5 hours and the 800ah pack was down low enough to engage engine start.
And how much extra $ was all this equipment to get that?
Does the key have to be in the ignition for voltrek to work? If not, having the doors closed doesn't make alot of sense unless the thought is to keep CO out of the cabin.
2019 Winnebago Travato GL
Old 10-18-2015, 01:28 AM   #9
the key does not have to be in ignition. just like remote start doesn't. it's made really to restart for pets. don't be so negative;
i just post it -lol
it's the slider by the way that has to be closed. front doors can still open
Old 10-18-2015, 01:32 AM   #10
wincrasher's Avatar
The Onan autostart has a provision that it will over-ride autostart if the vehicle hasn't been moved recently. The thought is you don't want it to start inside a storage garage.
I wonder if Voltrek has a similar provision.
Old 10-18-2015, 01:57 AM   #11
i don't know. i know it has to be push button set
Davydd has something like this. we could ask him
Old 10-18-2015, 02:20 AM   #12
4.5 hours sounds about right for a Ecotrek 800.
800 amp hrs x 0.9 percent discharge x 12 volts / 2000 watts = 4.32 hours
Why would anyone think that it should last much longer than this before engine start, wincrasher?
Old 10-18-2015, 02:26 AM   #13
Has anyone determined if Voltrek uses anything in the Sprinter beyond the normal remote start feature which may only work with all the doors closed as part of it's normal operation?
Old 10-18-2015, 02:31 AM   #14
wincrasher's Avatar
Well, the air conditioner should be no-where near 2000 watts constant.
It should be 1200-1400 watts continuous for around 30 mins per hour. So I'd expect a much longer run time. Could be he ran it on full so there was no hope of it cycling, but it still wouldn't hit 2000 watts.
Old 10-18-2015, 02:31 AM   #15
Hal amended his stuff. only the sliding door of his sprinter has to be closed. the front doors can still open
Old 10-18-2015, 02:33 AM   #16
picky,picky,picky
Old 10-18-2015, 02:34 AM   #17
wincrasher's Avatar
Maybe it's because I've eaten about 1/2 the Halloween candy and we still have 2 weeks to go.
Old 10-18-2015, 02:37 AM   #18
Sugar high will really do it -thats for sure
Old 10-18-2015, 02:44 AM   #19
Wincrasher, He had the thermostat set to 55 degrees so I expect the AC was running near full blast the whole time and how positive are you that you know what model AC it is and how many watts it uses?
I was taking a wag since I don't know those numbers but feel free to be more precise if it fulfills your need to be negative about all things Roadtrek...
Old 10-18-2015, 02:50 AM   #20
the dometic 11000 is about 11 AC amps so about 125 dc amps per hour
how warm was atlanta today
