OK the third time is a charm. First two battery replacepements were under warranty and thank you Roadtrek. The second time The Solar controller went out and batteries went bad. Replaced batteries and worn Alt belt. Later found that there was a flaw in the alternator pullies and the wiring was wrong. When the batteries were replaced they did with
GEL's. 3 years later I am finding the Gels going out and probably need to be replaced. I am concerned that there is a greater issue.
1) what is the original house battery (have 4) and what should I replace it with?
2) What settings do I need to adjust to make certain the settings are correct for either Gel's or AGM's?
3)What else should I be testing or checking to see if there are other issues?
Thanks
