Old 01-24-2022, 04:27 PM   #1
Default Roadtrek 2013 210P DC circuit breaker
Does anyone know if the main power switch breaker disconnects the house batteries from the battery separator? I need to change the separator out and I'm hoping the DC main breaker does the trick.
Diver007 is offline   Reply With Quote
Old 01-24-2022, 04:35 PM   #2
If you are talking about the 12v DC power switch on the control panel, no it does not disconnect the line to separator. If you newer van is the same as our 07 Roadtrek, nothing disconnects the separator line unless you disconnect the battery cables.
Old 01-24-2022, 04:48 PM   #3
yes, to be sure, disconnect the negative battery cable
while you are there clean the casing of the battery and if lead/acid check if it needs distilled water
