Old 09-18-2017, 05:26 PM   #1
Send a message via AIM to sewright33 Send a message via MSN to sewright33 Send a message via Yahoo to sewright33
Default Reset button
I have a 1997 leisure wide body and have had on the air and microwave and everything went off
Is there a reset button somewhere
I have had it plugged into hydro
Thanks for any help
Ann
sewright33 is offline   Reply With Quote
Old 09-19-2017, 04:40 AM   #2
It is called a circuit breaker in the power panel. If you can't figure out which one it is turn them all off, then on. Do not run the A/C and microwave at the same time, but you already learned that.
Old 09-20-2017, 12:55 AM   #3
You probably know what a circuit breaker is. The only thing left is the transfer switch. Maybe it has failed.
Old 09-20-2017, 01:26 AM   #4
First place to check is the breaker on the shore (hydro) power source, as that is very often the first one to trip when plugged in.
Old 09-20-2017, 02:04 PM   #5
Mike's Avatar
always been my first choice, too.
