Old 11-16-2017, 05:47 AM   #1
Default Replacing failed Transfer Switch on Roadtrek 1998
Hi,
My Transfer switch has apparently failed, it is not switching to GenSet 2800 output.
I measured voltage on Transfer switch (TS) input and Genset gives good power.
But TS only works from line power as is.
Side note, interesting enough before compete failure, generator would not handle microwave. After Transfer switch burn out, I've tried to direct connect genset bypassing transfer switch and Microwave works just fine.
Anyway, my question is how to remove Transfer switch from the back of Megantek? See attached pictures.
It seems like output of TS is going directly into Magnetec's breaker part?
TS is labeled as part # 91507234, is this now paralax part ?
Any advice is appreciated.
http://tinypic.com/r/j5z1hu/9
dessa is offline   Reply With Quote
Old 11-16-2017, 03:50 PM   #2
My transfer switch failed and it was the electronic board that actually failed.
I bought a new switch and removed and replaced the pc board and it solved the problem.
If you are not skilled at electrical then I'd advise having it fixed by a pro.
User1213 is offline   Reply With Quote
