Old 03-31-2020, 07:39 AM   #1
Default Replacement battery question
I need to replace two batteries on my epro 14fk trailer. This is the numbers off of the 2 batteries
hd24-dp 405cca 505mca. They are Interstete batteries. Walmart has a comparable battery but at 1000 MCA. They are listed as marine batteries. And have a number of MS 24 My question would it be alright to use 2 batteries with 1000mca each or should I try to get a closer match?
Thank you
PaulArthur is offline   Reply With Quote
Old 03-31-2020, 10:03 AM   #2
The 24MS - https://www.walmart.com/ip/EverStart...24MS/105864134 - from Walmart is a Marine Starting battery - not good for RV deep cycle use.
The 24DC - https://www.walmart.com/ip/EverStart...-24DC/49988408 - from Walmart is a Marine Deep Cycle battery and would be good for RV deep cycle use.
Old 03-31-2020, 12:51 PM   #3
I currently am using one group 29 DC Everstart Maxx battery for the coach. It is almost two years old and is performing wonderfully still. It gets about three months of dry camping per year, going on it's third season in another month.
It came with a two year replacement warranty.
I believe the group 24 dc is also available in the Maxx series for about $10 more. They claim 30% more charging cycles with the Maxx and it has the two year warranty instead of one.
Not sure of availability in group 24dc, I don't see it on their website, though I've seen them in the past at the store.
Old 04-06-2020, 02:27 PM   #4
The higher numbers indicate a better battery. So yes, you can use two MCA 1000, marine deep cycle. All marine batteries are a compromise for deep cycle use. But if you are satisfied with the use you got from the old batteries you will be good.
Sehc is offline   Reply With Quote
Old 04-06-2020, 02:43 PM   #5
Turns out that is not entirely correct with the "marine" batteries from Walmart. This is a Marine Starting battery:
and this is a Marine / RV Deep Cycle battery:
Old 04-06-2020, 03:10 PM   #6
If the gp24/27/29 "DC" series batteries are like the Costco/Interstate versions, which is very likely, they say on them that they are deep cycle batteries. In reality, that probably aren't in the sense that we have usually thought of that term. They may or may not have internal things to help with cycle life and depth of discharge handling, but hard to confirm that. They do have water checking and adding caps which normally would indicate that they would be traditional deep cycle chemistry which needs water additions.
I have had a couple of the DC series from Costco that I use for the starting battery in or Chevy Roadtrek 190. We had a gp27 first and now gp24 as it is easier to get in and out than the gp27 which was very tight and difficult. They are good batteries and last pretty well, but they don't behave like deep cycle batteries do to a large extent. The most obvious thing is that they don't really use any water, even on the charger for long float periods. I have had them on over an entire winter without having to add water. This would indicate a low water use design like is used in all the sealed starting and combo batteries, not deep cycle. They also don't come up to as high a voltage as the deep cycles we have had which would also. Both didn't really come up more than to about 12.6v except for when they had a bit of surface charge. Specific gravity readings were also lower at about 1260-1265 on the high end.
For those that are locked into those case sizes, they are probably among the better choices, but probably closer to a marine starting battery than a true deep cycle one. I think you can still get a true deep cycle 12v from Trojan and Crown, but not sure on that. Equipment batteries from them like for floor scrubbers are said to be quite good. IIRC, the Trojan one was 24MTX and was said to be a very good battery. We had a couple of the SCS series which had more output, but according to the old school dealear they weren't as durable, which is what we found also. The SCS batteries where decent but nowhere near what the later installed Trojan GC 6 volt ones were. They tested as new after 5 years of testing and abuse as we worked on various system configurations.
