Old 10-24-2014, 10:11 PM   #1
Ron
Default Re: Question Tripp-Lite Inverter
Would like to know if the Tripp-Lite Inverter requires a fuse in the Press To Reset Button area, I don't believe so, but asking.
Ron
File Type: jpg 2014-10-23-Tripp-Lite Inverter (3).JPG (305.1 KB, 455 views)
Ron & Rose Cabral
New Bedford, MA
2010-Chevy/RT-190P
FMCA:303873 ~K1RRC~ RRRCRT@aol.com
Ron is offline   Reply With Quote
Old 10-24-2014, 11:55 PM   #2
Bruceper's Avatar
Found this image on google images. It is a black coloured unit and not white, but everything else is the same including labelling, switches, lights etc.
http://www.mazersplace.com/images/PROJE ... VERTER.jpg
It appears as if the missing item there is a push button switch, just like the button to the left.
Do you know the exact model number so we can look for a manual?
Old 10-25-2014, 12:19 AM   #3
Ron
My manual makes no mention if it takes a fuse, but I am wondering if it does.
Ron
Ron & Rose Cabral
New Bedford, MA
2010-Chevy/RT-190P
Old 10-28-2014, 12:17 AM   #4
Tripp-Lite saw the post and sent a reply
No fuse required! This is just the circuit breaker to be pushed in to reset if needed. Hope that helps.
Old 10-28-2014, 12:20 AM   #5
Ron
Default Re: Re: Question Tripp-Lite Inverter
Thanks Mark
Ron & Rose Cabral
New Bedford, MA
2010-Chevy/RT-190P
Old 11-05-2015, 05:10 PM   #6
Sorry for reviving an old post but can someone confirm these circuit breakers require a push to reset them? The manual says they are automatic & reset by restarting the inverter.
I have lost 110 volt output but can't tell if the circuit breaker is tripped or not and restarting the inverter does not seem to work. Is there any way to visually tell if the white breaker is tripping?
2015 Roadtrek Agile
jrfaris is offline   Reply With Quote
Old 11-05-2015, 05:38 PM   #7
without a model number- this is a guess/ general statement:
when a circuit breaker is tripped a reset button will be poking out...depending on type in may be a black button with a white ring ( to show that is has tripped)...with everything turned off, push the reset button ...you may need to wait a few minutes for the breaker to cool off
push it it an it will latch, and the white ring will no longer be visible.
some other type circuit breakers are a lever (kinda like at home), or a small button poking out which needs to be pushed back in.
usually a tripped breaker will have a white or red part showing to indicate visually...but not always.
on some RV's a complete circuit may have a GFCI type outlet protecting a number of circuits- these are the type which are usually near kitchen and bathroom sinks at home- they have a black test button and a red reset button- check to see if you have any of these.
( for instance on my pleasure-Way, there is a GFCI outlet in the head- if that trips, it takes out the outlet in the galley and the outside outlet.
all 3 outlets are protected by the one outlet with the GFCI on the same circuit
mike
Old 11-05-2015, 06:03 PM   #8
It's a Tripp Lite RV750ULHW & the picture in the first post shows the white CB on the far left.
I've checked the GFI but it does not have power to the line input. The white post is about 3/8" extended (maybe a bit more than shown in the picture) but pushing it in does not lock it as I would expect. I was hoping someone would have some experience with this specific unit.
2015 Roadtrek Agile
