Old 05-03-2009, 12:09 AM   #1
Default Question on Inverter
I have a 99 Leisure Travel which has a 1000W inverter. My television is only DC. I have a regular electrical DVD player. When I want to watch a movie, I use the inverter. After being into the movie part way, everything shuts down and the panel for the inverter is blinking battery. When I check the status of the batteries from their panel, they are fine. Everything works on 12V. I had purchased an 800W inverter for my other little MH and had no problems. But it was much newer. Could my inverter be bad?
RTLover is offline   Reply With Quote
Old 05-03-2009, 05:29 AM   #2
Default Re: Question on Inverter
I experienced the same problem. It was with a 400 watt Xantrex inverter. After a half hour or so when watching a movie it would sound the low voltage alarm & quit on me. I never did figure it out. I upgraded to a 1200 watt inverter and never had any more problems.
Maybe: Bad inverter? Heat? Poor connection? I know it wasn't low battery with mine. Frustrating problem.
