Old 10-01-2017, 08:58 PM   #1
Default Question about amps
I just bought a Roadtrek Simplicity and am going on my first trip. So, here's how little I know. I'm trying to sign up for a campground and they want to know if I need 20 amps or 50/30 amps. How do I find the answer to this?
Thanks.
georgia_beth is offline   Reply With Quote
Old 10-01-2017, 10:48 PM   #2
Thanks.
What does the plug on your shoreside power cable look like?
Old 10-02-2017, 05:44 AM   #3
Thanks.
30 amp is the standard
Your RV comes with 30 amp plug,
which allows you to run the aircon or any high power appliances.
If you don't need the aircon,
you can request a cheaper 20 amp campsite.
But you might need a 30A to 20A adapter. (so-called dog bone)
With 20 amps, you can run all the low power appliances. eg. lights, TV, radio, furnace fan, etc.
Old 10-11-2017, 02:51 PM   #4
With the 20amp you can run everything just don't try to run everything at the same time. I do this often in friends driveway.
Haven't every tripped a circuit breaker.
Capt Ron is offline   Reply With Quote
Old 10-12-2017, 12:48 AM   #5
Agree. 20 amps is 2400 watts. Any one item will not exceed this. We have camped with a 20 amp plug-in often, and used coffee maker, microwave, griddle, induction cooktop , etc.
prfleming is offline   Reply With Quote
