Old 05-28-2020, 08:02 PM   #1
Default Promaster Zion 12V battery
Hi, can anyone help me find out what the OEM battery is and where it is on the Zion camper van?
Trying to determine feasibility of upgrading it to an LFP battery but not the ecotrek module.
Thanks in advance...
ElectricLove is offline   Reply With Quote
Old 05-30-2020, 03:36 AM   #2
Dogman's Avatar
TWO suggestions call GeneralRV.com as they sell the model and I'm only guessing but some Class B have located the Battery under the Passengers Seat area. Another idea is to look for your inverter and note the location of the RED power cable as the battery may be located on the same side and if you can spot the cable see if it runs forward or back should help locater the location. Now I don't work for anyone and about all I know is they are made in Germany correct? If you can ask them as the work on them and that should be a simple question. Good Luck
2021 Coachmen Galleria 3500XD, 24FL, with Li3.
We are H.L. and Jan, from the Sunshine State on Florida's west coast.
"Remember every camping trip is an outdoor adventure and begins and ends with a road-trip. Drive safely with your family cargo."
Dogman is offline   Reply With Quote
Old 05-30-2020, 11:07 PM   #3
i owned a zion 2015 with the agm battery
it was a Northstar sms agm 400. but beware the 400 stands for reserve capacity NOT amp hours
https://www.northstarbattery.com/product/sms-agm400
it was placed on it's side in the battery box
I also think you need to clarify your question. I'm talking about the 'house battery' added by roadtrek for the house section, some people are answering the starting battery for the promaster van. the starting battery for the promaster van is between the seats. remove the carpet and open the hatch
Old 05-31-2020, 12:24 AM   #4
Unless an upfitter moves it, the Promaster battery is in the floor in front of the driver's seat and rear of the pedals. It is most likely an AGM.
Old 05-31-2020, 09:12 PM   #5
Welcome to the forum ElectricLove!
I saw your other thread post that suggests you were looking for, and found, a 150Ah lithium coach battery that will work in your Zion. Correct?
https://www.classbforum.com/forums/f...tml#post109065
