Old 10-18-2017, 05:47 PM   #41
Originally Posted by Capt Ron View Post
UPDATE:
Roadtrek took the Trip Lite 1250 inverter out and installed a Magnum MM1212 inverter.
Now everything works as it should. The inverter will run the MW or the Onan generator will run it.
The problem was the Trip Lite inverter isn't compatible with the Onan Generator.
Magnum is a good brand, congratulation. I would assume your Trip-Lite inverter was simply kaput or wrong match for loads, I doubt that the failure had anything to do with the generator, just can't see a connection but I could be wrong.
Personally, I would choose a full sine inverter for microwave and induction stove – they are inductive loads, hopefully the modified sine wave will work.
Old 10-18-2017, 06:13 PM   #42
UPDATE:
Another example that RT does not test their products, either in the lab, or in the production run.
